It is currently Wed Aug 20, 2025 6:44 pm
 Post subject: Tinting Cyanoacrylate
PostPosted: Thu Feb 13, 2014 11:13 pm
Anyone have any good tips for tinting agents compatible with CA glues?
PostPosted: Fri Feb 14, 2014 2:10 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Lampblack is perfect for making it BLACK.
MEK - borne aniline dyes work well, but the MEK dilutes and catalyzes the CA. If you allow the MEK dye to dry almost completely in a little cup, then add the CA, you can get some good results. Take an empty aluminum soft drink can and turn it upside down to use the depressed bottom as your cup. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post (total 2): Ron Belanger (Fri Feb 14, 2014 4:44 pm) • brazil66 (Fri Feb 14, 2014 9:29 am)
PostPosted: Fri Feb 14, 2014 2:14 am
Last Name: Beaver
City: Lake Forest
I don't how to but I know you can buy it already tinted black so with the right dye it ought to be a piece of cake. I would guess an alcohol based dye.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Feb 14, 2014 2:16 am
Last Name: Beaver
City: Lake Forest
Looks like Frank has it covered.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Feb 14, 2014 10:29 am
First name: Rand
Last Name: Kennedy
State: CO
Transtint dyes also work but best to mix the dye in some thin CA first, and add that to any medium or thick if needed. That's a Dan Erlewine trick. I have not tried this with some of the more pigmented Transtint colors like black, tobacco brown, even the amber which tend to mix funny in lacquer.
PostPosted: Fri Feb 14, 2014 3:25 pm
Thanks all
